natural logarithm doesn't works in French language
Mikael_QUIJADA
Mentor Mentor
Mikael_QUIJADA
Just to say that natural logarithm doesn't works in the French version of Revit (2018 > 2020)
Works perfectly in the English version.
Mikaël QUIJADA
Expert Revit Structure
j.borne
Stuck too with this annoying bug, did you find any workaround ?
Mikael_QUIJADA
Yep : Using the English Revit version....
Mikaël QUIJADA
RDAOU
Didn't try but does changing Keyboard input language makes any impact/difference? sometimes it does German vs English … English vs German
JUST TO SAY:
If you need to carry out such operations to drive family parameters, it is preferable need to go through Dynamo/Python to do the calculation and write the output to the specified parameters.
There is a valid Formula Syntax / Abbreviation is limited to the list provided in the following document
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2014/EN...
Mikael_QUIJADA
I'll try but i don't think that make a difference.
This list is from 2014 and has been updated since then.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
Mikaël QUIJADA
RDAOU
I don't know … just saying maybe it helps...I have noticed that sometimes it does when scripting and keyboard input language changes by mistake...
Thinking that Revit's API should be same for all languages...why shouldn't a valid syntax work in one language not the other!
TS_HirokazuTaniguchi
For French version of Revit , replacing "In" with "Dans" seems to work
