Hello! Real basic - how do I add a parameter to my Grid family (Grid Head Family) to display an additional line for naming the grid line? See the attached image for clarification. I feel like this should be an easy fix but I can't quite find the right solution that isn't 'live text' in the plans.
Thanks!
When you like the bubble as is; edit your grid head type:
-Project Browser>Families>Annotation>Grid Head>Edit
-Create an extra label with some descriptive shared parameter and you are good to go
If you like to design a new one:
File>New>Family>Annotation>Grid Head
Create a shared parameter for your grids.
In the dialog where you can only choose for name, is a button left below to create a new shared parameter or browse for an existing one.
The shared parameter will effect all of the grids, no? I need a new 'instance' parameter that will allow me to alter the text for each individual grid line.
@Avaris. wrote:Create a shared parameter for your grids.
Will create short tutorial, I'll come back to you. Never mind, someone on the internet was earlier. In case you have further questions, just ask.
