I wonder if the name of a view that you add to a Sheet can be different to the name of the same source view on the Project Browser. Is this possible? If so, how to change the name of the view on the Sheet without changing the name on the Project Browser?
Thanks in advance.
Gelöst! Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
Name of the view on the sheet will be the same as the name of the view in the project browser.
However you can change the title of the view
Louis
Please mention Revit version, especially when uploading Revit files.
I also have a view on the sheet that is a 3D rendering, a rendered image inserted from the "Rendering" section of the Project Browser, and the tag shows a scale. However, on a 3D Rendering we do not want to show a scale and I want to take out that scale so nothing shows on that line.
How to take out the scale? (I looked on the Properties dialog and also on the Visibility Graphics but so far I haven't found the way).
Thanks in advance.
I just created a new thread named "How to omit the scale under the View Title of a Rendering on a Sheet?" since this issue of the "scale" showing on a rendering's Title View, and how to omit it, appears to be a new issue that might be interesting to know about. Please refer to that new posting since it has some additional information, etc.
Thanks in advance.
