Mystified by this sweep
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
james.levieux
818 Aufrufe, 9 Antworten
Hi All,
This sweep with segments in the new 2024 template blew me away.  I can't figure out how it's done.  The sweep curve is a simple arc and trajectory segmentation isn't involved.  The profile has some tricky stuff going on that I don't understand...there is a parameter "0" that seems to have no effect on the shape of the profile, so I'm mystified.
Does anyone know what's going on?
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: james.levieux
Do you want it segmented or no?  Either way, share the family here.
Nachricht 3 von 10
james.levieux
The family is attached.  I don't need it segmented.  I just want to understand what they did to get the segmented pattern lines.  I'm thinking they've done something that somehow affects the material pattern.
Nachricht 4 von 10
Change the Material or remove the Surface Pattern from the Material.
Nachricht 5 von 10
james.levieux
It's not quite that simple.  How do you get the pattern lines to radiate like that?  It's not normal (to me).  When I apply the same material to a similar arch sweep shape I just get parallel lines...like I always have....for decades.
Nachricht 6 von 10
Actually it is that simple.  Edit the sweep and look at the profile you will see it is has a slanted edge, and that make the pattern radiated.  if you straighten it up like the one you show then the pattern will not radiated.
And it is the same way since forever.
Nachricht 7 von 10
No different than any other version of Revit. Here's the same thing done in 2023.
Nachricht 8 von 10
You saw that the Sweep Profile is Rotated 90-degrees; didn't you?
Nachricht 9 von 10
james.levieux
Rotated 90 deg....mind blown.  Thank you.
Nachricht 10 von 10
....mind blown.
:zwinkerndes_Gesicht:
