Mystery Window at start up Revit 2014
4 REPLIES 4
Dion_Roland
876 Views, 4 Replies
I have a mystery window pop up everytime i start Revit. (see attached pic). It's the little window in the middle. If I right click it I can move it and close it but if I minimize Revit it will come back. It will also come back when i open a new family or project. Has anyone else come across this?
Tags (2)
4 REPLIES 4
sgoodmansen
in reply to: Dion_Roland
This is a video card problem.  Not sure what your video card is, but I have the same problem.  I have a AMD FirePro V4900
I get rid of the window by disabling Hydragrid in the Hydravision tab of Catalyst Control Center.
Dion_Roland
in reply to: sgoodmansen
Thanks. I have a NVIDIA Quadro 2000D. I will play with my setting and see if i can get it go away. If i can i will report back.
Thanks again.
Dion_Roland
I played with the setting and I still had the problem. So I installed an older driver from Nvidia and it fixed the issue. I installed the 307.45 driver.
octavio2
I have the same thing little thing always appearing  that I need to take out after I start the program.  It was also in Revit 2013.  Is this not something that Autodesk should have dealt with for some time by now?
Forma Design Contest
