My wall opening turns to full height automatically.
22931841
22931841
updated:
I just found the answer:
My wall is attached to the roof, but the "original height" of my wall is shorter than the opening. The opening recognised the original height and became full opening when it goes beyond that.
As the attached recording, I was making a simple wall opening, but it automatically became a full opening when reached a certain height. Is there a way to fix this? thank you!
Did you check "Do not show me this message again" at one point?
If so, you may need to change default in your Revit INI file.
https://help.autodesk.com/view/RVT/2022/ENU/?guid=GUID-0B67F556-4772-4DEC-B465-68C90843FBA4
yeah, I might unconsciously tick that. thank you!
