Hello, in our office we use several plants families for landscaping projects. They work just fine in viewport, but when i print this happen ( the solid fiil desappear whe the family is over a floowhen I print as .PDF
Viewportr)
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von mhiserZFHXS. Gehe zur Lösung
what PDF Driver are you using?
Howard Munsell
What Revit version are you using? Revit has a native PDF exporter as of R22.2 (I think that's when it launched).
I'm not familiar with that driver. Do you have access to any PC's with something like Adobe or BlueBeam? or as @mhiserZFHXS suggest, try Revit 2022.
Howard Munsell
Try using the native PDF export then. File -> Export -> PDF
I'm guessing its not the issue if Microsoft print to PDF didn't work, but its good to know this option exists now. It allows you to automatically name the individual files as well if you don't combine them. Its a good feature.
@viniciusN6K2V wrote:
I've tried "microsoft print to pdf" and still the same, my revit is a full 22
Use Revit native Export to PDF.
