My plant families are not showing the same way when I print
viniciusN6K2V
Message 1 of 13
viniciusN6K2V
Hello, in our office we use several plants families for landscaping projects. They work just fine in viewport, but when i print this happen ( the solid fiil desappear whe the family is over a floowhen I print as .PDFwhen I print as .PDFViewportViewportr)
Accepted solutions (3)
Replies (12)
Message 2 of 13
hmunsell
what PDF Driver are you using?
Howard Munsell
Message 3 of 13
viniciusN6K2V
doro pdf
Message 4 of 13
viniciusN6K2V
I've change to doPDF, but still the same..
Message 5 of 13
mhiserZFHXS
What Revit version are you using? Revit has a native PDF exporter as of R22.2 (I think that's when it launched).
Message 6 of 13
hmunsell
I'm not familiar with that driver. Do you have access to any PC's with something like Adobe or BlueBeam? or as @mhiserZFHXS suggest, try Revit 2022.
Howard Munsell
Message 7 of 13
Is your View Wireframe or Hidden?  Try changing it.
Message 8 of 13
viniciusN6K2V
consistent colors
Message 9 of 13
viniciusN6K2V
I've tried "microsoft print to pdf" and still the same, my revit is a full 22
Message 10 of 13
viniciusN6K2V
Used but still the same
Message 11 of 13
mhiserZFHXS
Try using the native PDF export then. File -> Export -> PDF
I'm guessing its not the issue if Microsoft print to PDF didn't work, but its good to know this option exists now. It allows you to automatically name the individual files as well if you don't combine them. Its a good feature.
Message 12 of 13
Use Revit native Export to PDF.
Message 13 of 13
viniciusN6K2V
thanks, problem solved
