My Level panel is greyed out
13 ANTWORTEN 13
Nachricht 1 von 14
10135 Aufrufe, 13 Antworten
I'm new to Revit. My Level panel is greyed out. I've switched everything on and off to see if it will light up, no luck. Does anyone have any suggestions?
13 ANTWORTEN 13
Nachricht 2 von 14
Alfredo_Medina
als Antwort auf: Anonymous
What do you mean by "level panel"? If you refer to the icon for creating levels being greyed out, it is because it is available only in elevations and section views, and you are probably trying to create a level from a floor plan view.
Nachricht 3 von 14
als Antwort auf: Alfredo_Medina
Thanks heaps. Sorry for the silly question.
Nachricht 4 von 14
My level icon is greyed out as well, even when I go to project browser click on elevations to east, west, north and south. it shows to levels and doesn't allow me to add levels (greyed out)
Nachricht 5 von 14
Can you share a screenshot showing the view, the panel with the grayed out level symbol, and the properties panel?
Nachricht 6 von 14
martijn_pater
By go to&click, do you actually mean opening this view or just clicking it in browser?...
Nachricht 7 von 14
Figured it out out need to double click on east, west, south or north to open up that elevation.
Nachricht 8 von 14
vpage200
Thanks! That would have taken me days to figure out!
Nachricht 9 von 14
Thanks. Been trying so sort this for 2 days.
Nachricht 10 von 14
kidibelay27
I tried all the above suggestions but it still grayed out. How can I fix it?
Nachricht 11 von 14
martijn_pater
als Antwort auf: kidibelay27
"It" is greyed out, what are we talking about? Adding levels under datum tab? Open a section or elevation view...
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Nachricht 12 von 14
mbmajeed
Thank you very much. My 5 hours problem is solved
Nachricht 13 von 14
als Antwort auf: mbmajeed
I have a hard time understand some of you @mbmajeed @Anonymous thought process.  If you are not in a section or an elevation view but a floor plan view, what would you possibly do even if the Level button were available?
Nachricht 14 von 14
RobDraw
als Antwort auf: ToanDN
Maybe it could be drawn with a rectangle and assigning an elevation. It's not possible in Revit but it's not a stretch to imagine a new user to think it could be possible.
Rob
