My gable wall won't attach to the top of the roof
13 ANTWORTEN 13
GELÖST
Nachricht 1 von 14
2248 Aufrufe, 13 Antworten
Hi, I can't attach my gable wall to the top of the roof. The base constraint only goes up to second floor, there is no roof line option.
Note: I am new to Revit.REVIT PIC FORUM 2.JPGREVIT PIC FORUM.JPG
13 ANTWORTEN 13
Nachricht 2 von 14
Kushnir.A
als Antwort auf: Anonymous
Hi! Select wall - press Attach Top/Base - select roof.
Best regards, Alexey Kushnir. | Facebook
Nachricht 3 von 14
als Antwort auf: Kushnir.A
Sorry I forgot to say that doing that is doing absolutely nothing, so I am out of ideas.
Nachricht 4 von 14
Kushnir.A
Can you attach the .rvt?
Nachricht 5 von 14
In the screenshots it looks like the wall is currently attached to a hipped roof (in a previous phase?)
If this is the case, you will need to put a new wall on top of the existing one and attach that to the new roof.
Nachricht 6 von 14
Sorry does that mean you want me to attach the whole file?
I'm new to this ha
Nachricht 7 von 14
Hi Alex yes this sounds correct.
How do I put a new wall on top of the existing? Because when I do, it doesn't actually become a gable wall it just becomes a big square wall protruding from the roof.
Nachricht 8 von 14
Kushnir.A
Yes, rvt project file. Just make a copy, then Manage/Purge unused, save and upload.
Nachricht 9 von 14
Try dragging the base of the new wall slightly lower until it will let you attach it to the roof
Nachricht 10 von 14
Ok hopefully this works?
Nachricht 11 von 14
revit help pic 22.JPGIt does this if I try to create a new wall
Nachricht 12 von 14
Is this correct?
Nachricht 13 von 14
YES!
How did you do it?
Nachricht 14 von 14
I disallowed join on both ends of the new wall, aligned it to the front and rear walls, attached it to the roof, and joined it to the wall below (making sure to switch the join order to keep the existing wall untouched)
