My drawing area in Revit isnt showing anything
19 ANTWORTEN 19
GELÖST
Nachricht 1 von 20
michaelwitherwick
3509 Aufrufe, 19 Antworten
After  having difficulty downloading the student software, i finally managed to get Revit 2019. However, the drawing area is always white and doesn't show anything, from drawing walls to loading the templates. I've checked the visibility graphics and filters too, nothing there suggests the cause of my issue.  Should I reinstall the software or is there something I'm missing?
19 ANTWORTEN 19
Nachricht 2 von 20
als Antwort auf: michaelwitherwick
Very Strange. Do you see any of the interface (e.g. Browser, Properties, Tabs, etc.)?
Nachricht 3 von 20
michaelwitherwick
als Antwort auf: barthbradley
Yeah the interface is there however, the viewing cube on the drawing area isn't there. I think the walls are being drawn, as I get a dialogue box alerting me that the walls overlap, however I cant see anything within the drawing area regardless the view.
Nachricht 4 von 20
First: Check these settings:
Nachricht 5 von 20
Second; check these settings (Plan View).  However, this wouldn't explain nothing showing in 3D.
Nachricht 6 von 20
@michaelwitherwick: Have you tried a Zoom Extents in 3D View?
Nachricht 7 von 20
michaelwitherwick
Cheers for the response. After trying out the suggestions, the problem still persists. Regardless of the view, I just simply cannot see what's within the drawing area. Its very frustrating, is there any other suggestion ?
Michael
Nachricht 8 von 20
Disable Hardware Acceleration see what happens.
Nachricht 9 von 20
Let's confirm what's happening: You open a brand spanking new RVT project from a template, Right? Which Template?
Then you draw walls on Level 1 and nothing shows  -- no walls in any views; Right?  What kind of Walls; Structural or Architectural?
Nachricht 10 von 20
michaelwitherwick
For example I open Revit, of which I close a dialogue stating that my Default template family file is invalid. Then I'd open Sample Architecture project or a new project, of which on no views is the project visible. On the new project I've been attempting to draw architectural walls into the floor plan 1, of which nothing appears.
Nachricht 11 von 20
Can you download and open the attached project see if you see anything?
Nachricht 12 von 20
I think it's plainly a bad install.  I'd suggest uninstalling and  reinstalling.  In fact, take the time to do a CLEAN UNINSTALL.  And make sure you reboot in-between.
...and temporarily disable Anti-Virus!
https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall
Nachricht 13 von 20
michaelwitherwick
Yeah no disrespect but I don't feel comfortable downloading files from a stranger sorry. Yeah I feel like that's probably the cause and solution. What's a clean uninstall btw ? Thanks for your help anyways :leicht_lächelndes_Gesicht:
Nachricht 14 von 20
It's not a file; it's a link, dude.  A link to the Clean Uninstall Instructions.
...and no disrespect to you Michael, but I suggest you get comfortable with downloading files if you want to learn/utilize Revit. There is a world of good information and content available to you through the world wide web that you'll miss out on otherwise.  Trust your anti-virus software.  It's got your back.  Smiley (zwinkernd)
Nachricht 15 von 20
michaelwitherwick
sorry I meant the files to toans response
Nachricht 16 von 20
Everyone here is a stranger. Do you expect we becoming your relatives in order to send you a test file?
Nachricht 17 von 20
als Antwort auf: ToanDN
Actually, @michaelwitherwick; we're all 400 lb. teenage Russian hackers.   What's your voter registration password, by the way?
Kidding.
300 lbs.
Smiley (zwinkernd)
Nachricht 18 von 20
michaelwitherwick
I best be careful Lachender Smiley
Nachricht 19 von 20
Viveka_CD
Hi @michaelwitherwick
Welcome to the community! I see that you are a new visitor! Smiley (fröhlich)
See the below article and let me know if this helps resolve your issue!
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Likes welcome.
Tags (1)
Nachricht 20 von 20
The best option is disable ¨Utilizar aceleración por hardware¨.
