So, I'm trying to place an Alarm Check Valve model (from Groups) into my modeling view. But I get an error saying none of the created elements are visible in Floor Plan.
I understand this is something to be changed under Visibility/ Graphic Overrides for Floor Plan. But I'm not able to decide which option should I tick. Any help?
I u
Gelöst! Gehe zur Lösung
Gelöst von syman2000. Gehe zur Lösung
I would adjust your plan view range. Often the object is pasted below or above the view you are in.
