MY ACT GRID PATTERN IS NOT SHOWING UP ON A CEILING THAT IS THERE
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
DESIGNDLS43
330 Aufrufe, 5 Antworten
MY ACT GRID IS ONLY SHOWING UP WHEN MY FLOOR PLAN UNDERLAY IS TURNED ON. I AM NOT SURE IF THIS IS A VIEW RANGE ERROR OR SOMETHING ELSE. ANYTHING HELPS, THANK YOU.
Beschriftungen (2)
5 ANTWORTEN 5
Nachricht 2 von 6
kostask_oionei
als Antwort auf: DESIGNDLS43
1. The Finish Layer must be below the lower core boundary.
2. If this doesn't work you have to change the View Depth in Properties -> View Range.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Nachricht 3 von 6
DESIGNDLS43
als Antwort auf: kostask_oionei
I HAVE TRIED CHANGING IT BUT ANY NUMBER COMBINATION I PUT IN DOES NOT SEEM TO FIX IT
Nachricht 4 von 6
kostask_oionei
I have corrected my answer
Kostas Kouris
Nachricht 5 von 6
DESIGNDLS43
MOVING THE LAYER DOWN FIXED IT. THANK YOU SO MUCH
Nachricht 6 von 6
kostask_oionei
Nice to help you
Kostas Kouris
