Multistorey stairs and Tread Numbers
3 ANTWORTEN 3
Nachricht 1 von 4
Kevin.Bell
497 Aufrufe, 3 Antworten
I've created several multi-storey stairs - and all looks fine.
I'm now producing the sections and want to use the 'Tread Number' tool (in the Annotation ribbon).
This numbers the lowest level of the stairs but I'm unable to select the stair treads on the levels above.
Is there a reason for this, or is it a bug?
Thanks.
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: Kevin.Bell
Which version? You can do it in 2018.
Nachricht 3 von 4
Kevin.Bell
Can you? Great if you can.
I use 2016 and 2017, I don't have 2018...
Nachricht 4 von 4
https://forums.autodesk.com/t5/revit-architecture-forum/staircases-multistorey-tread-number-tagging/...
See workaround for pre-2018 version and how it should work in 2018.
