Multiplying count total formula
4 ANTWORTEN 4
Nachricht 1 von 5
1076 Aufrufe, 4 Antworten
Hi All,
I'm trying to add a simple multiplication formula to itemized quantity totals I have categorized.   I.e., I have furniture CAD blocks that have multiple objects in one block.  So when I calculate the total amount, I'd like it to add, for example a CAD Block*10 to each CAD block to calculate a correct overall total.  Right now I'm identifying the blocks under Comments.  Is there a better way to organize this?
Thanks for the help!
T.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Set the Count field to Calculate Total from Formatting tab and untick Itemize every instance from Sorting/Grouping tab.
Nachricht 3 von 5
...well, if you're calculating totals, you need to work with numerical values.  "Comments" is a text value.
Nachricht 4 von 5
als Antwort auf: barthbradley
Calculate totals for Count column, not Comments column.
Nachricht 5 von 5
als Antwort auf: ToanDN
Could be I'm wrong.
I interpreted it as the OP was using the "Comment" field to input the number of blocks in the block.
"I have furniture CAD blocks that have multiple objects in one block" and "I'm identifying the blocks under Comments".
