Multiple Levels for Building Grading OR Separate Linked Models:
5 ANTWORTEN 5
GELÖST
Nachricht 1 von 6
819 Aufrufe, 5 Antworten
Hi All,
We are approximately at 30% DDs right now and are starting to get some grading numbers from Civil.
We are planning to step the building down to follow the grade (screenshot attached).
My question:
One model (as is currently) with multiple levels to follow grading down; or, split the model up and link in separate models at each level instance?
That is to say, one level or one linked model at +2, +1, 0 (central model most likely), -2, -1.
Any thoughts, ideas, or experience are greatly appreciated!
Thanks in advance.
Cheers!  :leicht_lächelndes_Gesicht:
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
If it is one building then one model.  You can add prefix/suffix to organize the levels, use scope box to scope the levels, and filters to hide irrelevant levels in views.
Nachricht 3 von 6
Are you just deepening the structural foundation, or are the Floor Levels actually changing at the building pads?  I mean, I don't see any apparent transitions --  much less enough room to make the transitions  -- on the overall Floor Plan.
Nachricht 4 von 6
als Antwort auf: barthbradley
Thanks for your reply, @barthbradley.
The levels are changing at the building pads.
This was first discussed just last Friday, so as you noticed, we have a lot of work to do.
@ToanDN, thank you for your reply, too.
That was my initial thought.  Splitting the model up was brought up at a team meeting, so I thought I would ask around.  I will mark as an accepted solution.
Appreciate the replies, Y'all!
Nachricht 5 von 6
Sahay_R
Splitting one building into separate models may give rise to issues in matching and coordination - this is one instance where Divide and Rule does not apply.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 6 von 6
...you could just raise the pads.  he,he.
Smiley (zwinkernd)
