I have a problem with my elevations.
I created multiple types of plans, elevations etc views, divided to types.
The problem is- whenever i'm viewing a specific plan (for example: draft), I can see the elevations of all the types (draft, permit, presentation, etc).
Is there a smart way to make sure i'll see only the elevations of the same type?
Thanks!
Amit
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Can you elaborate? Not clear what the issue is. Are you talking about Project Browser Organization? Filters? Something else?
Create different elevation view types for different purposes, then create view filters to turn off what irrelevant. View filters can also based on sheet number prefix, sheet title, view name criteria. For example, if you sketch sheets are SK-##, then you can filter all elevations with the sheet prefix = SK to be invisible on non-sketch floor plans.
