Multiple bubbles for one detail callout
2 REPLIES 2
Base12
1698 Views, 2 Replies
Often I have the same condition that occurs in multiple places nearby each other, and I'd like to point to multiple location with the same detail callout.  Kind of the same idea of text with multiple leaders, but with details.  See attached where the blue line is the desired line, and the red x'd out is the current solution.  I know you can do this by just drawing "dumb" detail lines representing the other callout(s), looking for a quicker method if there is one.
Thanks!
2 REPLIES 2
in reply to: Base12
Create a new call-out type using a blank symbol. Place the call-out on view referencing the other detail, and drag the end of leader to the symbol of the other call-out.
Base12
in reply to: ToanDN
Not a bad idea, certainly better than drawing the rectangle with detail lines!  Thanks for responding!
JP
Forma Design Contest
