MultiConnection System
2 ANTWORTEN 2
Nachricht 1 von 3
artur_dobriyan
198 Aufrufe, 2 Antworten
Hello.
I would like to know is there any way of pairing system connectors so one receives and other gives back.
I work with chillers for a moment and i have a task. Chiller is connected to a barrel and hladogent is circulating and comes back to the chiller. And other devices receives its cold exchanging heat. And there is a problem where it would connect to the other system and break the math. Is there any way of pair them sort of so they would math separatly.
All needed is in barrel family. Hope there is a way. Because I really dont want to make overcomplicated solution in formulas because ussually it brakes the projecct. And i dont want to make just hidden pipe inside of the barrel because it needs a bit more precise math.
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: artur_dobriyan
What about nesting shared Families/connectors together?
Nachricht 3 von 3
artur_dobriyan
als Antwort auf: barthbradley
By that. You want to make a chiller and a barrel as one family?
