Multi-type false tag
7 ANTWORTEN 7
Nachricht 1 von 8
cbt990
321 Aufrufe, 7 Antworten
I have to tag locations on walls where holddown straps are to be installed.
I created a new wall tag and rather than using a label, I added a text box to indicate the strap type.
I also created multiple types within the family and I would like each type to display a different string in the text box.
Do I need to use an instance parameter to set it up?
Revit is amazing
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: cbt990
Text box is static.  You need to use Label.
If you want text box, you need to create multiple text boxes, associate each with a Y/N type parameter, which turn on/off for each tag type.
Nachricht 3 von 8
cbt990
als Antwort auf: ToanDN
I'm not trying to tag a property of the walls. I'm just using a wall tag because it will create the leader for me pointing towards a wall.
Wouldn't a label grab a property of the tagged object?
Revit is amazing
Nachricht 4 von 8
Option 1a (preferable):
- create a Holddown text shared parameter
- add it to the project > walls category
- create a label in the tag family, add Holddown shared parameter
- load tag family in project and tag
Option 1b:
- create a label in the tag family and add Comments parameter
- load tag family in project and tag, enter Holddown info in Comments parameter for tagged walls
Option 2:
 - use Generic Annotation symbol with a label.  You can point to whatever you like and edit the label however you like without any complication.
Nachricht 5 von 8
No.
Nachricht 6 von 8
Yes.
Nachricht 7 von 8
cbt990
It wouldn't make sense to tag a property of the walls because the holddown isn't a wall characteristic, it's placed at specific foundation corners per structural. I just want to make a smart family with multiple text types rather than making three new families like this:
Thus, I am trying to understand what is the best way to edit this family I've created such that i can change the information in the text box from the type select dropdown.
Revit is amazing
Nachricht 8 von 8
Then don't use a Wall Tag, use a Generic Annotation family with a label.  You can place it, point it anywhere with single or multi-leader, enter the label value as you like.
