Hi All,
Yet another issue with stairs & railing in Revit (2017.2)...
I have a 4 story building. The first level's floor-to-floor height is 1.2 X. Levels 2-3 have a floor-to-floor height of 1 X.
The stairs are modeled as one, continuous stair set connected by landings.
I have two issues:
Solved by loboarch. Go to Solution.
Not a big fan of Multi-Story stairs because of challenges like this. I avoid them like the plague. That's my input: don't Multi-Story them.
You can get it to work, but you may need the "split railing" functionality tool from 2019 (that at least made it pretty easy for me). I am not sure if it can be done without it.
I got the on pictured to work by creating the multi story stair and then using the split railing tool to split the railing at the intermediate landing/flight, making 3 separate railings. Then i edited the top rail of the railing type to have the extensions at the top and bottom.
Once I had that i could attach to as many level as i wanted and all the edits carry through.
P.S. I know the request was about "wall mounted" handrails, I just did not have that type in the file I was working with. The pipe railing in my picture could have just as easily been wall mounted if i loaded that type into my example.
Looks like 2019 may turn my Multi-Story frown upsidedown.
Thanks for sharing
Thanks for sharing
Yes the split railing tool is pretty handy in these kinds of situations.
