I have a roof that I am trying to model. its is 6 sided, weird shape, see image below. I want it to a center roof drain. Is there any way to do this in Revit LT?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Of course. Model it as rectangular roof with negative slope on all 4 sides, then use vertical cut opening to cut it to shape.
Got Full Revit?
Use Modify Sub-Elements tools to shape edit a flat roof.
Just curious what that roof is supposed to be covering. Is that structure a Portico? If so, why a center drain? Maybe to wash the cars parked underneath? ![]()
