Multi Line Label
3 ANTWORTEN 3
Nachricht 1 von 4
Samuel_Mangiarelli
509 Aufrufe, 3 Antworten
Multi Line Label
I am trying to make a family where the last label has multiple parameters in it because some of them won't be needed every time so they are not visible until you put text in. However, I want one of my parameters to take up two lines. One for the Prefix and then one for the actual text. Is this possible? Pictures and Family are attached.
In the picture my goal is to get the highlighted text underneath the underlined text.not.png
3 ANTWORTEN 3
Nachricht 2 von 4
syman2000
als Antwort auf: Samuel_Mangiarelli
To achieve the line separation, you have to add several empty spaces to push the value toward the right. Is this what you wanted?
Nachricht 3 von 4
Samuel_Mangiarelli
als Antwort auf: syman2000
So I tried that, but all it did was shift it further and further away and kept increasing the label's width. I also tried changing the space number but it didn't seem to do anything.
Nachricht 4 von 4
Samuel_Mangiarelli
I got it to work. I just had to unselect the wrap between parameters box.
