Multi layered wall to host 1 element
Hello.
I have a multilayered wall. The core of the wall is existing and the external insulation render is part of a new construction phase.
For instance, when I add a door, Revit picks up only one wall and I would need to pick up both. I have recorded a screencast so you can see.
Thanks.
artejon
Join the walls, then placing a door will cut both walls.
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
@artejon
I am trying to join them without much success...
artejon
They must have already been joined.
