Hello folks,
I am trying to create a multi-color fill tag. I am doing a basic simple set as follows;
Within the TAG FAMILY, I am creating multiple colors fills assigning a parameter for each color. When I assign a TYPE family with a "yes/no parameter" the color fills are not showing up on my family types. What am I doing wrong? Thanks for your help.
Gelöst! Gehe zur Lösung
Gelöst von rxi.gg. Gehe zur Lösung
You have to create one annotation family for each color.
Then charge all families in your main family.
Create a paramerer by type of family: annotation - I named it Color Fill
Then insert one of the annotation family (blue for example) in your main family, select it and put in Tag text the parameter we just have created "Color fill"
This way you can choose the color of each type of family.
I upload you the family with red and blue colors
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Your family only have one Blue Filled Region. You need to add a filled regions for each and every color.
Good morning guys.
RXI GG, I struggled a little bit trying to figure out what you showed me. Finally, I was able to accomplish the objective. I do appreciate the time you have put into this. Thank you.
