Multi-Category Tag instance parameter not showing
3 ANTWORTEN 3
Nachricht 1 von 4
jagostinho74
1165 Aufrufe, 3 Antworten
Multi-Category Tag instance parameter not showing when loaded into the Project model file.
Type parameters show, but not instance.
Found about this when trying to push the Wrap Between Parameters Only parameter. It would be very useful to control text wrapping at an instance level.
Assistant BIM/CAD Manager
Manchester, UK
Tags (1)
3 ANTWORTEN 3
Nachricht 2 von 4
Viveka_CD
als Antwort auf: jagostinho74
Hi @jagostinho74
Thanks for sharing the issue and screencast. I have logged this with the dedicated resource team.
Thank you for your patience while we investigate this issue.
Nachricht 3 von 4
JF.K
als Antwort auf: Viveka_CD
Instance parameters still not showing with Keynote tags in Revit 2022.
How difficult is to implement such a feature?
Nachricht 4 von 4
als Antwort auf: JF.K
Wrong topic. Keynote tags are not multi category tags.  Open your own topic to get it answered.
