Hello all, just downloaded 2022 so pumped for the features this time around!
I am a big fan of multi category tags (basically use them for everything) but the first thing i noticed was that i can no longer tag my columns (arch). i thought for sure it was because i made my own columns ( many years ago) and something changed in 22 but i cant tag any (arch) column? works great in 2019?
columns are made with extrusions
tag is a multi category tag that reports the 'description' parameter (the one built into the families)
up until now I was only sad that i could not tag elements like 'Fascia' (i use a material tag.. but it feels like a such a dirty way to use the material tag... ps love the material tag too)
anyways.. any help is appreciated!, (also hope its real simple and i am just missing something) thanks
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
@Anonymous
As far as I know they extended the functionality of multi-category tagging ...not reduced. I for sure can still tag Structural columns families with it
What category is that family? would you like to upload it?
yep i noticed that the structural columns still work with the multi C tags, that's a reason I'm so confused.
i attached the family
thanks
There is no such thing as Column Tag in Revit 2022 so that explains why your multi-category tag doesn't pick up Architectural Columns. You could Create Parts from those columns and tag them with a Multi-category tag, though.
There was no Column tag in previous versions too...that's why Architectural columns were tagged using the Multi-category. Now it doesn't even picks it all or prompt at least prompt wrong family!
Revit 2022 New Feature: Untaggable elements lol
It is weird though that the multi-category schedule still picks up Arch Columns in 2022 so there is no reason that justifies why it got excluded from the MC Tag... @Anonymous You can change its category for the time being, most probably they will fix in the upcoming update
i was hoping the answer was more along the lines of ... just go into the family a check or un check this super obscure check box... haha
thanks for looking into it, fingers crossed for the next update
