I am creating a curtain wall with the automatic placement of mullions. I can change the position of my mullions, however, my mullions seem to be dis attached from the curtain wall itself. I have checked the mullion properties, but the offset values are already to 0. How do I get the mullions to attach to the curtain wall
Thank you.
Gelöst! Gehe zur Lösung
@Anonymous hello, can you post your mullion so we can check. thanks
Is this the setting you've checked? (see image 1)
If yes then, also check the setting of your mullion (see image 2 and image 3)
Ahaan...That worked...Turns out that it was my glazing that was offseted and not my mullions. Thanks a ton for the help
@Anonymous
