Hello Folks
I have tried everything from VG to templates etc to try and view my mullions in plan view, that exist in in 3d in the model.. Here is a screenshot of the mullion and you can see the 4 dots outline. How can I show them in plan view again. Thanks
It looks like someone has made the lines invisible using the linework tool as you can still see the dots in the corner representing the vertical lines of the mullion.
Use the linework tool and set it back to "by category".
Hi @AIDANJHAWKINS3HJ6V ,
How do they look if selected?
Are all the mullions like this, or just the one?
If it's all, likely there's a override for the Cut style of the line is set to dots or something. (in Object styles of the view or viewfilters.)
Also create a new floorplan view from scratch (not a copy of a existing) without a viewtemplate and see if they show up ok.
Thanks a lot for posting your question to the forums! Has the solution suggested by @barthbradley @Mike.FORM @TripleM-Dev.net helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
