Mullion family with inserted angled curtainpanel
11 ANTWORTEN 11
Nachricht 1 von 12
b.jongsmaD7XSQ
567 Aufrufe, 11 Antworten
Hi, I try to make a mullion where the curtainpanel will insert at an 10 degree angle.
Is there any why to make for example the center refrence plane is on 10 degree angle on both sides of the profile?
Attached is an screenshot of what I try to achieve, and the model I the mullion is in.
Beschriftungen (2)
11 ANTWORTEN 11
Nachricht 2 von 12
als Antwort auf: b.jongsmaD7XSQ
Can't you use an L-Corner Mullion for that?
Nachricht 3 von 12
b.jongsmaD7XSQ
als Antwort auf: barthbradley
With an L profil its not possible to insert an 'real' profil (see screenshot).
Or am I wrong?
Nachricht 4 von 12
What about creating a custom Mullion Type for that specific angle?  Duplicate existing Type and change the Angle Parameter Value of that new Type.
Nachricht 5 von 12
b.jongsmaD7XSQ
I tried that, but the thing with that solution is that one side of the mullion will connect gooed, but the other on is just cutting trough the profile. And if possible it would be nice that the curtainpanels on both sides of the mullion will connect nicely to the profile.
Nachricht 6 von 12
Yeah, I see. It's a challenge for sure.  Why model such an "ornate" mullion? Why not Details for this?  Anyhow, I don't readily see a straight-forward and easy approach. Maybe Beams? Dunno.  I do know that I would use a L-Corner Mullion in the meantime.
Nachricht 7 von 12
b.jongsmaD7XSQ
Yes, you're correct. This would be beter as een detail. But the architect, want a detailed mullion for in the projectfile.
But I will discus, this further.
Anyways thanks for you time.
Nachricht 8 von 12
Use L mullion and nest a detail components of half the profile in a custom panel family.
Nachricht 9 von 12
b.jongsmaD7XSQ
als Antwort auf: ToanDN
This sound like something that could work.
But this is an new idea for me. How do you nest a profile in a L bracket?
Nachricht 10 von 12
That's not what I suggested.
Nachricht 11 von 12
you could use a custom rectangular mullion using a Half mullion Profile .When put together we'll have a complete mullion...
Constantin Stroescu
Nachricht 12 von 12
Yes your right. But then still you have the problem that the profile can only be used for specific angles.
Thanks for trying to help, but I think i'll just let it slide :leicht_lächelndes_Gesicht:
