The issue with the mullion columns appears that it is only showing one family, but when I clicked on the mullion I am not able to edit the type of family or to duplicate the type of family. What I want to do is to be able to have one set type of mullions so that the material only applies to those mullions and then for my windows I want it to be another type. I do not want the mullions to be the same as all of them.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Unpin the Mullions, select one (or more) and replace with another one shown in the Preview Selector.
....to create a new Mullion Type with a different Material. do this:
- Do it from model: Select a mullion > Unpin > right click > Edit type > duplicate to create a new type.
- Do it from project browser (recommended): just select a mullion type > right click > edit type > duplicate to create a new type.
@barthbradley It appears that in properties that the selection is grayed out after creating the new family the name is Wood Frame which is shown here. What could I do to fix this?
Great!
Let's see that lil' green check mark then. I need one more to win a toaster from Autodesk.
