hello
as the title suggests , i would like to model MSE wall (its a type of Retaining wall, that consists of wierd shaped blocks, similer to the attached image)
please advise.
It depends on the way you want to use the model.
The easiest way is to model it as an ordinary wall and add a pattern to the material.
Mostafa Elashmawy
There are several ways, but it all depends on the level of detail you want for the model... Above mentioned wall with model pattern is generally a good way (or starting point anyway). If you would want to model each block, I think using a patterned surface could be a good approach. Or... you could 'ofcourse' go full lego-style ;D
