Nachricht 1 von 13
svilen2110
590 Aufrufe, 12 Antworten
Mr
Since downloading REVIT 2022 I'm experiencing problem of corrupted RVT files, that can't be open. It is not with one,
but two Projects already. With REVIT 2021 end earlier versions haven't experience such an issue. Is this only problem
of my system or it is a bug on RVT 2022 ?
Second question is if there are some options to recover the corrupted file ?
P.S. Even now when trying upload the problematic file as an attachment to this post the system is rejecting it with the following message :
 "Correct the highlighted errors and try again.
  • The attachment's lobby design 02.rvt content type (application/octet-stream) does not match its file extension and has been removed"
Really strange !
Thanks, Svilen
12 ANTWORTEN 12
Nachricht 2 von 13
RDAOU
als Antwort auf: svilen2110
@svilen2110
No issues with upgraded models here...Did you download the latest Hotfix/Update 2022.1?
You should be able to upload .rvt files.
Try upload it to Wetransfer.com or Google Drive or Dropbox and past link here
Nachricht 3 von 13
svilen2110
als Antwort auf: RDAOU
Thanks for the prompt reply ! Can I have am email id to upload the file on WeTransfer
Nachricht 4 von 13
svilen2110
The Link to the RVT File :
https://we.tl/t-hS9irFGiK9
Nachricht 5 von 13
Have you tried opening the 2021 file in 2021 and "cleaning it up" (i.e. Audit, Purge, Resolve Warnings, etc.)?
FWIW: File upgrade process for Revit | Revit 2018 | Autodesk Knowledge Network
Nachricht 6 von 13
RDAOU
@svilen2110
  1. DO you have a copy of the file before upgrade
  2. If not, do you have any automatic backups of the .rvt (should be .000X.rvt) ...
  3. if you do not have any can you post the Journal (Check for latest generated when you were upgrading)
Journals location should be %LOCALAPPDATA%\Autodesk\Revit\<Version>\Journals
Nachricht 7 von 13
svilen2110
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" /><meta name="Generator" content="Microsoft Word 15 (filtered medium)" /><!--<br>/* Font Definitions */<br>@font-face<br> {font-family:"Cambria Math";<br> panose-1:2 4 5 3 5 4 6 3 2 4;}<br>@font-face<br> {font-family:Calibri;<br> panose-1:2 15 5 2 2 2 4 3 2 4;}<br>/* Style Definitions */<br>p.MsoNormal, li.MsoNormal, div.MsoNormal<br> {margin:0cm;<br> font-size:11.0pt;<br> font-family:"Calibri",sans-serif;}<br>a:link, span.MsoHyperlink<br> {mso-style-priority:99;<br> color:blue;<br> text-decoration:underline;}<br>.MsoChpDefault<br> {mso-style-type:export-only;}<br>@page WordSection1<br> {size:612.0pt 792.0pt;<br> margin:72.0pt 72.0pt 72.0pt 72.0pt;}<br>div.WordSection1<br> {page:WordSection1;}<br><br>
Nachricht 8 von 13
svilen2110
Nachricht 9 von 13
syman2000
Can you upload the 2021 file before it was upgraded? I like to test out from my end if my 2022 experiencing the same issue.
Nachricht 10 von 13
svilen2110
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" /><meta name="Generator" content="Microsoft Word 15 (filtered medium)" /><!--<br>/* Font Definitions */<br>@font-face<br> {font-family:"Cambria Math";<br> panose-1:2 4 5 3 5 4 6 3 2 4;}<br>@font-face<br> {font-family:Calibri;<br> panose-1:2 15 5 2 2 2 4 3 2 4;}<br>@font-face<br> {font-family:Tahoma;<br> panose-1:2 11 6 4 3 5 4 4 2 4;}<br>/* Style Definitions */<br>p.MsoNormal, li.MsoNormal, div.MsoNormal<br> {margin:0cm;<br> font-size:11.0pt;<br> font-family:"Calibri",sans-serif;}<br>a:link, span.MsoHyperlink<br> {mso-style-priority:99;<br> color:blue;<br> text-decoration:underline;}<br>.MsoChpDefault<br> {mso-style-type:export-only;}<br>@page WordSection1<br> {size:612.0pt 792.0pt;<br> margin:72.0pt 72.0pt 72.0pt 72.0pt;}<br>div.WordSection1<br> {page:WordSection1;}<br><br>
Nachricht 11 von 13
RDAOU
@svilen2110
Unable to decipher your replier :verwirrtes_Gesicht: this is how they read at my end
Nachricht 12 von 13
svilen2110
Can I send the reply to another email?
Nachricht 13 von 13
RSomppi
You can come to the forum and post instead of responding in an email.
