Moving the Project Base Point + the whole project
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
a_paynter
8395 Aufrufe, 6 Antworten
Hi there,
i need to be able to move my entire project to the following coordinates using the project base point:
N/S   - 5405161.2470m
E/W   - 3517477.6549m
in Revit 2020 this way easy, just select the PBP and put in the numbers. As long as it was "clipped", everything in the model moved with it.
In Revit 2020.2 and after, there isn't a clip anymore, the PBP is just kind of free-range. You put those numbers into the PBP and it moves without taking any of the geometry with it - or at least it would if those distances weren't so far away from the Internal Origin Point.
How can we do this? Obviously there is the "move project to new position" command, however this does not have the precision required here
6 ANTWORTEN 6
Nachricht 2 von 7
RDAOU
als Antwort auf: a_paynter
@a_paynter
You can use the Specify Coordinates at Point
Nachricht 3 von 7
a_paynter
als Antwort auf: RDAOU
my man, you the man
thank you very much for that boss, you just made an office and a surveyor very happy
Nachricht 4 von 7
RDAOU
@a_paynter
You're welcome.
If your surveyor's plan in AutoCAD or Civil 3D is georeferenced, you can do the above by
  1. linking the DWG >>>
  2. aligning that reference N/E point you mentioned with the reference point in Revit then >>>
  3. acquire coordinates from the link >>
  4. save/sync (same menu shown above - that's how you set up shared coordinates)
PS: if you haven't done that before, test it out on a sample project to get the hang of it
Nachricht 5 von 7
DomEdwards
Just to chip in on this. Is it not the survey point that you are talking about clipping and unclipping? I still find the difference between PBP and SP confusing!
Dom
Nachricht 6 von 7
igor.rozanski
My model didn't move when I used this method.
Nachricht 7 von 7
My coworker just ask me the same question as well. he is using useing revit 2022, i am using revit 2020.
the servey point and project point in revit 2020 has paper clip sign where u can change the coordinate and the struture will move with the point.
yet in revit 2022, there is no paper clip sign for project point.
to solve the problem, we use " manage - project location - position - relocate project " to move the struture first.
After that we change the porject base point coordinate.
