Apologies in advance if this has been posted before (I couldn't find much), but I am looking to move my firm's Revit template and configuration files (project templates, family templates, shared parameters file, etc.) to a Revit standards project on BIM Collaborate Pro. The issue I'm having is two-fold:
1. The Revit.ini file will not convert c:\%userprofile%\... to the user's profile path. I've worked through this issue by using symbolic links to path "c:\<company name>\DC\" to "C:\%userprofile%\DC\...". However, this results in issue #2.
2. Once symlinked, I cannot force the required project folder to sync on everyone's machine, as there doesn't appear to be an API for the Desktop Connector published or commands able to force a sync.
If there was a command or API call to do that, I could use a login script to force sync on machine login. But...that doesn't seem to be possible.
Any ideas? Has anyone else successfully moved their Revit project/family templates to either BIM360 or BIM Collaborate Pro?
Thanks in advance,
Garth
