Moving project base point
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
BIM_Dreamer
401 Aufrufe, 2 Antworten
how to adjust this project basepoint to 1st storey level with affecting the value of 1st storey level.LEVS2.jpg
2 ANTWORTEN 2
Nachricht 2 von 3
kostask_oionei
als Antwort auf: BIM_Dreamer
Move the project base point to 1st storey level.
In tab Manage -> Coordinate -> Specify Coordinates at Point and click the Project Base Point. Put the 1st storey level elevation.
If my post help you, please give a like.
If your question was answered please mark it with ACCEPT SOLUTION. This helps others to find answers...
Kostas Kouris
Architect Engineer, M.Sc., ACI, ACP
Nachricht 3 von 3
Move the survey point to the same Elevation as the project base point.  Edit the level type to use the survey point for Elevation base. Move the project base point to where you want.
