Moving levels in elevation individually
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
2992 Aufrufe, 2 Antworten
Hello all,
I'm trying to move level bubbles in elevation/section.
However, when I try to move one specific bubble, all the others move along with it. I like that all of them move together as it makes it easier, however in this case I only need particular levels to move individually (for graphic purposes) without affecting the other levels.
How can I detach this level from the other?
Thank you :leicht_lächelndes_Gesicht:
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
Reveal constraints (button on the bottom status bar, looks like a dimension with a padlock) and unlock the padlocks on the dimensions between the levels.
Nachricht 3 von 3
als Antwort auf: ToanDN
