So I'm about to need to move an entire building in one of my models. However, as I make this adjustment, the elevation views become framed incorrectly and all will need re-adjustment. Is it possible to constrain the view with an element, so when it gets moved the window will follow? Or is it possible to select all the elevation lines, not just the arrow/circle icon so I can just repeat the movement to fix all the views at once?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Unfortunately not since i need to move one building out of two so the problem persists, granted it means manually adjusting only half of the project.
Just a idea...what if you built a selection set filter of all the elements you need to move? Might streamline the process if you are moving everything the same distance (e.g. everything is to be moved 2 feet up).
That's the reason modeling each building in its own file has been recommended when you have multiple buildings on site.
