What is the most optimized way to adjust the area boundaries according to the new walls in the design?
I have checked the box "moves with nearby items", but when I move a wall, the area boundary is not adjusted.
I'm looking for the most optimized way because I want to use the settings for all the future projects, so it is not just one project that I can adjust manually.
It depends on how you place them...they will move with the walls in the following cases
If the walls boundaries were not associated to walls, then you would need to lock them together.
