Moving a group of text without moving the location of the leader location? Level Head in detail view to show wainscot height?
childressNHMUH
childressNHMUH
I'm trying to format some sheets of construction documents. I want the details and text to fit neatly on the sheet and to not look too spaced out or close together so they're easier to read so moving text in groups while keeping the leaders in their locations could speed up production time. If you select a single text note with a leader and hold the directional arrow (I've highlighted in the image attached) to move the text the leader will stay in its location. Is there a way to select multiple notes (With leaders set in their correct locations calling out items in drawing) and move them while keeping the leaders in their locations on the detail?
Also if you look at the image attached you will see I've created a dummy elevation tag. If anyone has a link to a good way to create and use a dummy elevation tag that would be helpful. or a way to use the Level head family that will match the one I use in my elevation views?
Simon_Weel
Maybe the Align app?
