I have received a coordination model from a client in a .NWD fromat but the model is miles away from origin making it very difficult to work with and very difficult to drag back to origin. is there a way to move it back to origin without needing to drag it for miles?
Alan
Try asking in Navisworks forum please
https://forums.autodesk.com/t5/navisworks/ct-p/4
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
What was your Positioning set to when you brought in the Coordination Model? Shared?
Do your Revit model and the Coordination model share coordinates? There are only two positioning options when you insert the coordination model: Origin to Internal Origin; Shared Coordinates. Have you tried both?
i have it as origin to origin at the moment, shared coordinates didn't help.
