Moving a building on the site
I've imported a cad survey plan and used shared co-ordinates from the cad file to get the correct geographic data in my model.
I've created topography and a building in the same model.
We've decided to push the house forward by 4m on the site, and lower the building by 600mm.
I can't figure out how to do this whilst keeping the integrity of the shared co-ordinate system from the cad survey.
I explored separating the model and site into two different models. I've then imported the building model into the site model and shifted the buildings position on the site.
The problem I have is when I publish the co-ordinates to the building model, then link the site model into the building model. The position of the building in plan gets updated, but the elevation of the building doesn't. If I try to use the relocated model tool to adjust the levels, I can get the levels aligning, but then I end up with the building sitting 600mm higher on the site that it should be.
There's a lot of discussion online around this topic, but I'm struggling to find what is the best approach to solve my situation. Some guidance on this would be much appreciated.
