Move tool: Lock to single axis
1 ANTWORT 1
Nachricht 1 von 2
TDC94
4643 Aufrufe, 1 Antwort
I'm trying to move an element in plan view to align with a nearby element. When moving the element it only allows me to constrain movement to X and Y axis, therefore if it is a small distance it aligns moving in the Y direction when I want it to align moving in the X direction.
Is there a way to set the constraint to a single axis?
In SketchUP you can use the arrow keys to lock the constraint to any axis. Is this not possible in Revit?
Thank you.
Tags (2)
Beschriftungen (1)
  • Move
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: TDC94
Uncheck "Constrain" and check "Disjoin" on the Options Bar. .
