move project original then after flex, unable to match grid system
heichan88
heichan88
hello,
I made the whole building with grid line, at first the project original had been set at the corner of the grid system,
now due to match the linked project, I need to move the project original to the center of the grid system. But after flex the building, the original move around.
maybe at first time I align the corner grid to the original, so now the whole grids lost the aligned original?
(2) the original point of linked project (roof) is set on the center, so different from the host project, so that cause the problem
(3) I had tried align the center grid of linked project with host, but after flex, it also moved away. ](4) if there is solution about setting original? or only use monitor/copy?
Please advice.
heichan88
I am trying redraw the center X-Y grid then re-dimension that. hope it works
Project Base Points don't matter when you link projects and share coordinates.  Steps:
- link the other model in, center to center
- move the link to align with your model and acquire coordinates
- move the project base point to wherever you need it to be
- do not move the survey point, or if you must then unclip it before moving
