Hi fellas!
I'm trying to move everything from a workset to "workset1", how can this be done?
Removing the workset doesn't seem to work (greyed out even after using "Editable)
Thanks in advance!
Constantin Stroescu
@constantin.stroescu wrote:
- open a 3d overall View
- in VGO , go to Workset and hide all Worksets but the one you want to merge to other workset
- with Cross Selection select everything that appears on display (only that one workset) and from Properties change the Workset to the desired one.
I actually tried this, but the option/parameter "Workset" was greyed out here as well. I guess that some objects can't be moved? (...can groups be moved?)
you can not delete a Workset unless it is empty..exception for Workset 1 that can not be deleted but you can change its name...
If you make a Group, then every member of the Group will move to the Active Workset...even if you Ungroup , the elements will remain on the former Group's Workset...
Constantin Stroescu
use Worksharing Display Settings in order to make visible Workset by colors - it is much easier to identify which is on what...
Constantin Stroescu
My bad fellas! Someone renamed Workset1 to another name.., got really confused! This is solved now, thanks for your help.
