Move baluster inside landing
12 ANTWORTEN 12
Nachricht 1 von 13
665 Aufrufe, 12 Antworten
Hello Friends,
Can anybody let me know how to move these balusters 2" inward? I attached the files. Thanks
12 ANTWORTEN 12
Nachricht 2 von 13
Ilic.Andrej
als Antwort auf: Anonymous
Simply edit the railing path...
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 13
oops. I think you mean this:
Nachricht 4 von 13
als Antwort auf: barthbradley
It didn't work. It doesn't move the first one.
Nachricht 5 von 13
What about changing the spacing of your start/end posts instead?
...I just opened your file. I don't see a way to do that as a contiguous rail using your rail type.
Nachricht 6 von 13
It is Grayes out. I attached the file
Nachricht 7 von 13
Yeah, I looked at it. I don't have an easy fix. I don't think there is one.  It's a challenge for sure.
...I would probably built it differently. I would not put the glass in as Railing, but instead as a Baluster Panel.
Nachricht 8 von 13
Nachricht 9 von 13
See attached.
Nachricht 10 von 13
als Antwort auf: ToanDN
Toan, I don't want to manually edit the path all over the project. I believe you can find a way :zwinkerndes_Gesicht:
Nachricht 11 von 13
You know you can edit the Top Rail path independently and add 2" on either side. Just TAB-select it.  Wouldn't that accomplish the same thing as a 2" end post inset?
Nachricht 12 von 13
I fixed it as attached. Thanks for efforts
Now the problem is, how to shift glass 2"?
Nachricht 13 von 13
I wouldn't inset the Post Balusters 2 inches.  I would TAB-select the Top Rail, press Edit Rail and then add a 2 inch sketch line at both ends.
You can't inset your Glass because it's defined as a continuous Rail.
