Mouse Pointer Accuracy - Revit Architecture 2016 / Windows 10 / Parallels 13
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
970 Aufrufe, 2 Antworten
I am running Revit Architecture 2016 on Windows 10 through Parallels 13 on my MacBook Pro. In any model or drafting view, the mouse pointer is inaccurate. When moving the mouse pointer towards an object, the object highlights before the pointer is over the object. It is as if the selection area around the tip of the pointer is expanded. This is especially problematic when there are multiple objects within an area. Any ideas?
2 ANTWORTEN 2
Nachricht 2 von 3
-FDC-
als Antwort auf: Anonymous
Not a Revit issue.
Maybe your mouse or graphics card driver?
Did you install their latest drivers?
Maybe you can try to disable hardware acceleration in Revit
Nachricht 3 von 3
Viveka_CD
Hi @Anonymous
Thanks for posting on the forum.
It's been a while and I wanted to check back and see if the suggestion by @-FDC- helped.
Let us know if you have additional questions and please accept the solution if the post helped resolve your issue.
Looking forward to your reply update.
