Monolitic Stair
2 ANTWORTEN 2
Nachricht 1 von 3
Ilic.Andrej
168 Aufrufe, 2 Antworten
Monolitic Stair
How to fix the connection between the stair and the landing?
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
2 ANTWORTEN 2
Nachricht 2 von 3
vitorbortoncello
als Antwort auf: Ilic.Andrej
make a continuous run:
do not forget to check the heights
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 3
Ilic.Andrej
als Antwort auf: vitorbortoncello
Thanks. I never thought of this solution.  But, I assume another problem here. You cannot annotate properly a stair with 100+ risers...
Andrej Ilić
MSc Arch
