Monolithic Stair
Monolithic Stair
emersongonzalez1999
Monolithic Stair
emersongonzalez1999
So I have a Base Monolithic stair which depth is 52 inches and when I created another stair it has the same depth of 52 but when I change it to 7 inches it creates a hole kinda to the one that was already created. I want the stair to be different depths but not to affect the other.
RDAOU
@emersongonzalez1999
You need to do the following
  1. Start Stair
  2. Edit Type
  3. Duplicate the Type and Rename
  4. Edit Run Type
  5. Duplicate and Rename >> Change Structural Depth of the new type
  6. Apply/OK to Finish Run Type Edit
    • Repeat for the Landing if needed
  7. Apply/OK to Finish Stair Type Edit
  8. Place new Stair type
emersongonzalez1999
Thank You So Much For The Video Tutorial
