is there a way to make staires like this:
I only managed to obtain this in Revit:
As pictured above, I need to insert four treads at the stairs beginning???
Gelöst! Gehe zur Lösung
Gelöst von PijPiwo. Gehe zur Lösung
Convert component stair to sketch and draw your winders, or create entire stair by sketch.
Thank you so much!
One more thing,......I see a small arc in 3D at the center or the first four treads! Is there a way to adjust it?? It is not visible in Plan view, all the lines (treads) intersect at the same point!!!
I don’t think there is a way around it, at least not that I know of, other than workaround like applying the treads to the stairs, that however, will give you tread lines on the sides.
